Reply to topic  [ 5 posts ]
 h4 adapter
Post h4 adapter
Has anyone tried these?
http://pages.ebay.com/link/?nav=item.view&id=271457232317&alt=web
Do they work?
Cheers,
October 9th, 2014, 9:18 am
Post Re: h4 adapter
these seem to be plastic... I used to have a pair of metal ones, altough it was a different model, worked fine for me, much more light in the darkness then with original duplo ones.
you could also change the complete headlight (without housing) bit for a H4 type, more expensive, but that is ok for sure (watch out for bad reproduction!!!)
one other thing to check is the Voltage left at the headlights, if you still have the original wireing and ligthswitch it might just be you r loosing 3 volts from the battery though the lightswitch through the wires to the headlights! best fix is to install a relais as close as possible to the headlights and use the original current to operate them and get some new wires straight from the battery to the bulbs, also saves the lightswitch (mine used to get realy hot -> means lost power!!)
not realy a straigt forward answer to your question, but I hope it helps.
greetzzzzzzzz, Rusty
bitten by the Citobug...
October 9th, 2014, 10:13 am
Post Re: h4 adapter
http://www.ecas2cvparts.co.uk/adapter-c ... -2117.html
I've Been Wrong Before.
October 9th, 2014, 2:13 pm
lovin' the snatch
Post Re: h4 adapter
Harley they do work, i've had them since my last 2cv and carried them over to the dyane, all i will say is that they're not the most perfect fit and mine have started to warp a little bit, they still do the job though, i'd say they have a 2 year life!
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
October 9th, 2014, 4:44 pm
Post Re: h4 adapter
Or you may get a pair of these:
http://www.retrospecparts.com/citroen-p ... white.html
Also have a look:
http://www.thewessexducks.co.uk/2cv_032.htm
And don't overlook Rusty's recomendations.
It's funny that the French are interested in fitting old type bulbs to H4 socket! :shock:
October 9th, 2014, 7:01 pm
