| Desperately trying to make use of crap: Front arms http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5416 |
Page 1 of 2 |
| Author: | Russell [ October 8th, 2014, 6:54 pm ] |
| Post subject: | Desperately trying to make use of crap: Front arms |
So, there's a rusty pile of shonky 2cv parts that I consider my 'spares pile'. Amongst this decreasing heap of rubbish were a pair of front arms. I need a pair for my 2cv so I got them out today to clean up. First thing I noticed was the play in the kingpin, or perhaps the washer, because all the play is 'up and down'. The swivel hub moved about 2mm along the kingpin. I assume this is wear in the washer or the little cup thing that sits over it? Anybody know the dimension for eye end of the arm? Also, the knife edge hole is worn for some reason, am I pissing in the wind here or is there any reason I can't just chop that bit off my old arms and weld it on? Unrelated to my questions, a couple of observations: Undoing a hub nut with the arm off the car is a right caper and furthermore removing a kingpin with the arm off the car is a shit of a job. |
| Author: | Sean [ October 8th, 2014, 9:14 pm ] |
| Post subject: | Re: Desperately trying to make use of crap: Front arms |
king pin isnt so bad you need to balance the big end on an axle stand while the KP housing is on a 50mm or so wood block on the floor while deployoing the big hammer up and down free play was 0,4mm limit by Citroens standard which is quite a clonk |
| Author: | Russell [ October 8th, 2014, 9:17 pm ] |
Where the free play coming from? Is it the washer thing or is it likely to be the arm that's worn? |
| Author: | Sean [ October 8th, 2014, 9:37 pm ] |
[quote="Russell"]Where the free play coming from? everywhere! the face of the KP hole is usualiy dished and the swivel housing gets worn too just draw a sharp file over the surfaces and youll see what sort of state they are in after 40 yrs of road grit and dry grease |
| Author: | J-dub [ October 12th, 2014, 9:58 pm ] |
I found changing my kingpin with the arm off OK, clamped it in the vice |
| Author: | ken [ October 13th, 2014, 12:16 am ] |
Probably means that the fit of the pin in the arm was on the slack side, since the correct interference fit requires the use of something with a bit more clout than a toffee hammer to drive the pin home... Jameswallace wrote: I found changing my kingpin with the arm off OK, clamped it in the vice
| Author: | ayjay [ October 13th, 2014, 1:18 am ] |
russ i sent my bro your first post with your number, he needs 2 for his lomax i.ll mosey along and see him this morning give it a bit of time cheers andy |
| Author: | Russell [ October 13th, 2014, 6:50 am ] |
Thanks Andy, but I have sold them now, pending collection. |
| Author: | ayjay [ October 13th, 2014, 6:49 pm ] |
ok russ |
| Author: | J-dub [ October 15th, 2014, 1:04 am ] |
ken wrote: Probably means that the fit of the pin in the arm was on the slack side, since the correct interference fit requires the use of something with a bit more clout than a toffee hammer to drive the pin home... Jameswallace wrote: I found changing my kingpin with the arm off OK, clamped it in the vice ![]() I'm to ill to undersatd the joke, but to clarify i meant clamped the arm in the vice not press fitted it with the vice |
