Does not idle
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5380
Page 1 of 1
Author:  Tripyrenees [ August 31st, 2014, 11:12 am ]
Post subject:  Does not idle
My little AZU is suffering on idle. It just suddenly appeared that when I take my foot of the accelerator the engine stops. Even with the idle screw adjusted in, it still just cuts off unless I keep revving.
Any quick things to look at before I start stripping the carb down.
Also - is it a common fault that the brake master cylinder loses fluid (cannot see any leaks anywhere), are there reconditioning kits out there for this old girl.
Cheers
Ian
Author:  Nelsthebass [ August 31st, 2014, 11:46 am ]
Post subject:  Re: Does not idle
Sounds like idle jet is blocked......
Author:  Tripyrenees [ August 31st, 2014, 2:30 pm ]
Perfect - Thanks
Followed this instruction - http://www.mbzponton.org/valueadded/mai ... 3/idle.htm
And everything is purring again. :D
cheers
Ian
