View unanswered posts | View active topics It is currently June 19th, 2026, 12:47 pm
Reply to topic  [ 3 posts ]
 Does not idle
Post Does not idle
My little AZU is suffering on idle. It just suddenly appeared that when I take my foot of the accelerator the engine stops. Even with the idle screw adjusted in, it still just cuts off unless I keep revving.
Any quick things to look at before I start stripping the carb down.
Also - is it a common fault that the brake master cylinder loses fluid (cannot see any leaks anywhere), are there reconditioning kits out there for this old girl.
Ian
August 31st, 2014, 11:12 am
Post Re: Does not idle
Sounds like idle jet is blocked......
August 31st, 2014, 11:46 am
Perfect - Thanks
Followed this instruction - http://www.mbzponton.org/valueadded/mai ... 3/idle.htm
And everything is purring again. :D
cheers
Ian
August 31st, 2014, 2:30 pm
Users browsing this forum: No registered users and 209 guests
