Reply to topic  [ 7 posts ]
 Ah crap....
Haggis Muncher
Post Ah crap....
I was a bit of a twat and forgot to remove the rod from the crankcase hole when I was rechecking the timing - went to start the engine, heard a CLUNK, scratched my head for a minute then noticed what I'd done.
There seem to be dire warnings about removing the rod everywhere I look (such as "FOR GOD'S SAKE REMOVE THE ROD BEFORE GOING ANY FURTHER!" on the wessex ducks website) but the engine started fine after I removed it.
Could I have done some invisible damage that will rear its ugly head in the future?
August 6th, 2014, 7:45 pm
Post Re: Ah crap....
Happened to me last week on a costumer car mounting 1-2-Spark, normally no harm is done, I Always use a drill 6mm and they brake (good drill) or bend (loosy drill) Take a good look if all the pieces of the rod are gone so no more harm can be done......
August 6th, 2014, 8:32 pm
Unlikely that the engine is damaged but if you used a drill bit I doubt it'll be much good for drilling holes any more.
I used to have a rod with a hole in on my key ring so When the rod was in the hole so was my ignition key and I couldn't accidentally start it, seemed sensible at the time.
August 6th, 2014, 9:18 pm
I've done the same trick myself .....I always used an aluminium tent peg .....they bend quite easily,so no harm done.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
August 6th, 2014, 11:17 pm
If you think about it, the starter motor's torque is transmitted direct to the flywheel, which either shears the drill bit or bends the rod, so the engine never notices a thing.
It's more nuisance value than anything else, having to dig out a bent rod... :roll:
Btw, if you use Tippex to mark the flywheel, it'll be a while before you have to repeat the exercise.
https://www.flickr.com/photos/30132857@ ... YHW-9ivWwH
August 7th, 2014, 1:03 am
yes, but only to your self esteem and pride. Counseling is the answer there will be plenty of it available at the beer tent in Anglesey.
August 7th, 2014, 7:59 am
Haggis Muncher
Thanks, doc - I'll make sure to get my g̶l̶a̶s̶s̶ prescription filled multiple times to ensure I make a speedy recovery!
August 7th, 2014, 11:57 am
