View unanswered posts | View active topics It is currently June 19th, 2026, 10:45 pm
Reply to topic  [ 3 posts ]
 Car runs a bit uneven
Post Car runs a bit uneven
Hi folks
I have this little issue with my 2CV, fitted with an engine, carburetor and gearbox of the last/newest models.
It actually runs and drives very well. Smooth tick-over, good throttle response and pulls smooth and even as long as the second stage opens in the carburetor.
The only minor problem, which I would like to do something with, if I can, is this little uneven run at certain rpm's in certain speeds, when under load.
It is worst going up hills in like 40 to 50km/h (25mph). The more rpm, the less noticeable. OR, at very low revs.
If I open the throttle so that the second stage opens, it pulls smoothly and powerful.
If I reduce the throttle, so that the car hardly accelerates, it runs smoothly also.
Would you say it's a worn carburetor or should I try different jets? What's the best jets for the best fuel-economy without the uneven run? Or is it something completely else?
Suggestions welcome :)
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
June 18th, 2014, 9:21 pm
Post Re: Car runs a bit uneven
Sounds like mine used to be - King Ken suggests a larger primary jet than the original which should stop the lumpy running on light throttle
June 18th, 2014, 9:38 pm
Needs to be 107.5...
June 18th, 2014, 9:40 pm
Users browsing this forum: No registered users and 199 guests
