View unanswered posts | View active topics It is currently May 1st, 2026, 10:51 am
Reply to topic  [ 6 posts ]
 torque wrench
Post torque wrench
hi guys - what range of torque wrench will cover most jobs on my 2cv?
your views are greatly appreciated
rr Ash
May 3rd, 2014, 9:25 pm
Post Re: torque wrench
Usually you need at least two torque wrenches to cover the complete range for 2CV, avoid using them in the outer ranges, so you'll need a small overlap.
Not sure about the numbers but a look in your Haynes could give you the exact numbers.
May 3rd, 2014, 9:40 pm
Britool AVT300A 5-33NM 40-300ftlb for engine work BUT- DO NOT FOLLOW RECOMENDED TORQUE FOR CYL HEAD BANJO BOLTS they will strip at 10nm half it and see if it leaks then nip it till it doesnt - they are accesible trough the fan housing and the engine will run for 10 mins from cold, no fan, with no ill effects
1/2 in drive for some chassis stuff but usually my weight x distance on the long breaker bar for wheel bearings and the like
May 4th, 2014, 10:08 am
Inhave a 1/4 teng tool torque wrench and a 1/2 cheap screwfix one
Both dont see daylight often enough but seems to cover the complete range
May 4th, 2014, 10:26 am
thanks guys - very helpful for a numpty like me, I did look at screwfix and thought the reviews were quite good!
May 4th, 2014, 10:35 pm
Have a look on Ebay ... I bought a Britool half inch drive torque wrench on there for just over twenty quid.
May 5th, 2014, 2:27 am
