| Mini Owners - what electrical connector? http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5213 |
Page 1 of 2 |
| Author: | samfieldhouse [ April 11th, 2014, 12:12 pm ] |
| Post subject: | Mini Owners - what electrical connector? |
FAO those of you that have had or do own the other A series, what electrical connector do I need to attach a wire to the back of these switches? Thanks. |
| Author: | subarupete [ April 11th, 2014, 12:23 pm ] |
| Post subject: | Re: Mini Owners - what electrical connector? |
try these http://www.vehicle-wiring-products.eu/V ... mepage.php http://www.carbuildersolutions.com/uk/electrical |
| Author: | Sean [ April 11th, 2014, 3:58 pm ] |
samfieldhouse wrote: FAO those of you that have had or do own the other A series, what electrical connector do I need to attach a wire to the back of these switches? Thanks. picture of the BACK might have been helpfull Lucar on the later ones IIRC its been 30 rs since i had a Mini Bullets on the early ones? Just get them and then you can work out what you need . |
| Author: | samfieldhouse [ April 11th, 2014, 4:06 pm ] |
I have them (at parental home) but still can't see what I need... looks like 3mm bullet terminals? |
| Author: | Sean [ April 11th, 2014, 4:10 pm ] |
yep same as the crimp bullets used to fix on to the coil. |
| Author: | Russell [ April 11th, 2014, 6:54 pm ] |
Ask Dave Boulton on Facebook, or I can pass his number on, he will have the bits you want. |
| Author: | nodmoz [ April 14th, 2014, 3:18 pm ] |
Bullets. Female multiblocks are what is fitted to the car. (like on the back of an 80's D*lly's hazard switch, but round). Minispares might have them? |
| Author: | samfieldhouse [ April 26th, 2014, 12:12 am ] |
So my learning has taught me this evening that the spades provide (always on) illumination of the switch. Such illumination it hides the decal telling you what the switch does! On the 2 pin switches the pins are simply + and - and are switched by the switch, handy. Irritatingly the smallest of my small bullet connectors is too big so I need to work out a way of attaching a cable. ![]() ![]() Mini spares do a plug thing but at £5 a go it seems expensive. Any ideas why minis use spades AND bullets? |
| Author: | samfieldhouse [ April 26th, 2014, 12:17 am ] |
And with the six pin plugs, the top for are switched + and - but weirdly, the bottom two work the other way, i.e. i goes live when the switch is off, is this to switch between circuits? |
| Author: | Sean [ April 26th, 2014, 8:05 am ] |
BL was a law unto its self the change over to the almost universal Lucar spade conector would have probably sparked a national strike involving Liverpool dockers and London bin men and the panick buying of sugar. |
