View unanswered posts | View active topics It is currently June 19th, 2026, 8:07 pm
Reply to topic  [ 9 posts ]
 shock absorber bushes
Post shock absorber bushes
does anywhere do replacement bushes???????
regards Ash
March 31st, 2014, 11:49 pm
Post Re: shock absorber bushes
yes someone on here posts pictures up Think its Paul from 2cv Tech so calling Paul or Harry!
April 1st, 2014, 7:51 am
If you measure the stud and the damper eye to get the sizes I sure you should be able to get bushes. These are fairly easy to fit with a length of stud and a couple of large washers, with little lube to draw the bushes into the damper eye. There's loads listed on ebay :-)
April 1st, 2014, 11:24 am
Take the old ones out (with a vice and some sockets), measure the hole and compare with this: http://www.superflex.co.uk/datasheets/SuperFlex%20Universal%20shock%20eye%20bushes(3).pdf
Maybe number sf0814p will fit?
Stainless pipe 16x2mm is standard available and fits the 2CV shock absorber bolt perfectly.
April 1st, 2014, 11:36 am
thanks guys on it now!!!
pdf is v helpful!
April 1st, 2014, 11:42 am
pdf is v helpful!
keep us updated on your findings.
April 1st, 2014, 11:49 am
many thanks the 0814 ones are perfect , all fitted now with only minor swearing
April 3rd, 2014, 9:57 pm
What oil are you running Ash? gearbox? Ready for Croft :D ???
April 3rd, 2014, 10:21 pm
got some sesame oil from sainsburys! but had EP140 on the label
April 3rd, 2014, 10:26 pm
