View unanswered posts | View active topics It is currently June 19th, 2026, 7:04 pm
Reply to topic  [ 8 posts ]
 Low oil pressure
Post Low oil pressure
Hi - quick question
What's the cause of a 2cv oil pressure light flickering/staying on at idle? Engine has oil in it and otherwise is reasonably ok. The light goes off as the revs rise.
Thanks
Will
1979 2cv6 (Evie)
1983 Beachcomber (Mavis)
1991 AXGT Mk1
2008 C5 2.0 HDi VTR+
January 6th, 2014, 1:50 pm
Post Re: Low oil pressure
Bad oil pump or an oil leak
January 6th, 2014, 1:58 pm
Tired pressure relief valve?
January 6th, 2014, 2:12 pm
switch/sender on its last legs. Dirty terminal :D
knackered oil pump, worn bearings :cry:
January 6th, 2014, 2:30 pm
Thanks for the replies - it'll either be a £7 easy fix or an engine rebuild then..... 8-)
1979 2cv6 (Evie)
1991 AXGT Mk1
January 6th, 2014, 2:53 pm
Another option..... oil to thin, try typical classic car oil.....
January 6th, 2014, 5:54 pm
Good point - it is a 2cv I have just purchased so although the engine is well topped up with oil who knows what type it is! I'll replace the pressure switch and change the oil for some 20/50 or 15/40 and see what happens.
1979 2cv6 (Evie)
1991 AXGT Mk1
January 6th, 2014, 6:17 pm
Halfords sell a 15w/40 mineral engine oil, which I use. Works just fine. Perhaps give that a go?
January 6th, 2014, 10:02 pm
Users browsing this forum: No registered users and 181 guests
