View unanswered posts | View active topics It is currently June 19th, 2026, 7:04 pm
 help with steering joint
Post help with steering joint
I bought one of these from burton.....
http://www.burton2cvparts.com/swivel-jo ... -5539.html
but not sure of how I am going to get the steering column to fix to it as its female both ends as you will see
help please
rr Ash
December 30th, 2013, 9:39 pm
Post Re: help with steering joint
You will probably need an adaptor
i do not think the splines are 2cv
Try Zx BX or Xantia steering column parts
they could fit
pony
i
December 30th, 2013, 10:47 pm
Hi Ash I know I have the same on my race car, I will get you a picture tomorrow so you can see what I use if that helps
Simon
December 30th, 2013, 11:14 pm
that would be excellent Simon, much appreciated (starting to stress now January is just about here)
and thanks also Pony
December 30th, 2013, 11:20 pm
Ash,
unless you lash out for the Burton steering column as well*, that joint won't be much use to you...
* Stainless steel and € 225,00 :shock:
http://www.burtoncar.com/dms_temp/image ... 003--0.jpg
http://www.burton2cvparts.com/stuurkolo ... anguage=en
December 31st, 2013, 1:07 am
I used a joint from a GS, it is a long section with a UJ at each end, you will need to cut and weld a section but it fits the spline.
Harley
December 31st, 2013, 9:49 am
There you go Ash this is whats on mine, hope it helps
December 31st, 2013, 5:53 pm
that looks different to the joint I have, mine is approx. 4 inch long and its female at both ends, you would have thought that it would be female on the bottom end to go directly onto the rack and male top for the steering column to attach to but alas not
January 1st, 2014, 9:24 pm
Weld it at one end?
January 1st, 2014, 9:44 pm
Ash,
have you looked at the links I posted above, which show that the UJ sold by Burton is designed solely for use with their version of the steering column, which is in two pieces and has the UJ positioned about mid-way between the wheel and the pinion? :roll:
January 1st, 2014, 10:01 pm
Users browsing this forum: No registered users and 181 guests
