View unanswered posts | View active topics It is currently June 19th, 2026, 3:26 am
Reply to topic  [ 5 posts ]
 Steering Wheel Swap
Post Steering Wheel Swap
Is it a simple swap from 2 spoke steering wheel (D*lly) to a single spoke (Charleston) type? Someone told me the column needs rotating by 90 degrees to correctly position the single spoke - is this correct? If so, straight forward?
ta
September 21st, 2020, 5:24 pm
Post Re: Steering Wheel Swap
As I recall, it does need to be rotated......You need to take out the bolt at the base of the column, (in the engine bay) Pull the column up and rotate.....Getting it all pointing in the straight ahead direction can be a challenge ....I had a couple of goes at it !
September 21st, 2020, 6:05 pm
If you've still got the steering lock ring fitted, you'll need to remove that first in order to pull the column up high enough to clear the pinion.
September 22nd, 2020, 1:01 am
Ahhh, My steering lock was removed, (after it locked up unexpectedly :shock: )
September 22nd, 2020, 9:30 am
I swapped my two spoked "standard" 2CV {Special} steering wheel for a single spoke {Charleston/Club/Dyane?} wheel ....the spoke now resides at somewhere around the 10or11 o-clock position ....which to be perfectly honest, is no problem at all IMHO.
BTW ....just a thought, but I was under the {prob'ly mistaken} impression that the idea of a single spoke was so that the steering wheel "collapses" easier in the event of a collision ...therefor it would seem rather silly {IMO} to position the spoke at anything like 5 to 7 o-clock.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
September 24th, 2020, 2:47 am
Users browsing this forum: No registered users and 199 guests
