View unanswered posts | View active topics It is currently June 19th, 2026, 8:45 pm
 Bench testing
Post Bench testing
When rebuilding an old engine, how does one go about setting it up and bench testing it?
Can anyone give me a step-by-step to bench testing? I'm a complete novice. I've never tried it before, or even watched someone else doing one (a bench test, that is).
Ta.
November 13th, 2013, 1:16 am
Post Re: Bench testing
heres a vid
November 13th, 2013, 4:54 pm
boring, take this one 8-) 8-) 8-) 8-) 8-)
November 13th, 2013, 6:42 pm
Okay, so I need an engine and a ratchet strap and something to lash the engine to, plus a battery and a fuel supply and an ignition. Any pitfalls?
November 14th, 2013, 9:34 am
Fresh Air?!
November 14th, 2013, 10:31 am
Ratchet straps only needed if you're trying to impress onlookers... ;)
Some sort of cobbled together exhaust is handy, unless it's an early engine the with crossover type manifold.
http://www.flickr.com/photos/30132857@N06/9509103728/
http://www.flickr.com/photos/30132857@N ... o9i-9456q4
http://www.flickr.com/photos/30132857@N ... S5h-bHGMyx
November 14th, 2013, 11:48 am
Hey! you call my engine test boring!!?? :shock: :roll: 8-) :D
Anyway, it was a test of a motor that had been sleeping for 10 years.
For my test I had:
- Battery negative to ground on gearbox/engine.
- Batteri plus to starter
- Batteri plus to positive terminal on coil (red cable on picture)
- Coil negative terminal to ignition (blue cable on picture)
- Then short plus and the starter pin where the yellow cable is connected on the picture. I had the yellow and red thin cable going to my start button just for fun 8-) A few pictures:
1975 Mehari 652cc & 1-2-Spark
November 14th, 2013, 9:07 pm
Smiffy wrote:
........... something to lash the engine to..............
I just sat my engine and gearbox assembly on top of a couple of tyres. It didn't need lashing down, as the tyres absorbed any movement. I had a crossbox attached, plus the rest of an old exhaust system to take the fumes out under the garage door (and to keep the neighbours happy). It's worth having a complete exhaust on so you can check more easily for any nasty engine noises.
November 14th, 2013, 11:53 pm
Sorry Backfire didn't know it was yours...... hope your'e not angry with me.......
If it had a 1-2-Spark ignition on it..... it would instantly looked diffrent ;) ;) :oops: :oops:
November 15th, 2013, 12:03 am
How long do these engines last for?? I'm pretty impressed at 64BHP, that's pretty much modern high performance (hot hatch or sporty saloon) standard in terms of BHP/litre.
November 15th, 2013, 1:22 am
Users browsing this forum: No registered users and 243 guests
