View unanswered posts | View active topics It is currently June 19th, 2026, 8:30 pm
Reply to topic  [ 9 posts ]
 Popping and spitting
Post Popping and spitting
My car has decided to pop and spit when letting off thr throttle on overrun. I've checked and adjusted points and timing and tried to check for exhaust leaks but still seems to be doing it any ideas what to check next?
October 17th, 2013, 9:38 pm
Post Re: Popping and spitting
sounds like-/imo- the carburetor to the manifold heat insoulator maybye cracked--
on over-run air gets sucked into the manifold
its an easy repair if ur hands on
October 17th, 2013, 11:23 pm
I'd totally forgotten to check that! Will check tomorrow after work. Just been out in it tonight and it dmells as if its running a bit rich too.
October 18th, 2013, 12:08 am
did you 'really' check the exhaust.
Even a tiny leak at the front clamps can cause this.
October 18th, 2013, 5:26 pm
I did but maybe not well enough I couldn't find anything but very hard to tell any sneeky tips on how to find leaks ?
October 18th, 2013, 6:01 pm
A 1 metre length of windscreen washer tubing cannot be described as sneaky, but it is very effective for pinpointing any exhaust leaks.
Tip originated from Roy @ ECAS.
It shouldn't be necessary to go to this extreme... ;)
October 18th, 2013, 9:24 pm
I carry 1m of garden hose in my Ds for just that!
I get weird looks standing over the engine bay with the hose pushed into my ear!
Harley
October 19th, 2013, 6:28 am
check for the leaks at the manifold block and also inlet manifolds into cylinder heads by spraying brake cleaner or WD40 around them when engine is running - revs will drop noticeably if you have a leak....
October 19th, 2013, 7:15 pm
Finding Engine Vacuum Leaks With A Cigar.
http://www.youtube.com/watch?v=zMok2y05jNE
I've Been Wrong Before.
October 31st, 2013, 9:57 am
