View unanswered posts | View active topics It is currently November 20th, 2025, 2:56 am
Reply to topic  [ 6 posts ]
 Roof removal/swap
Post Roof removal/swap
Anyone have any hints or tips for this? I have a red roof to go on my Special 8-)
1988 2CV Special
1969 Singer Chamois
October 1st, 2013, 6:49 pm
Post Re: Roof removal/swap
The only advice I'd give is to refrain from piercing the roof with the two screws at the back for a couple of weeks to let the roof settle a bit. Otherwise it's pretty straightforward.
October 1st, 2013, 7:10 pm
Have a look at this link Charlotte :D :D http://easyweb.easynet.co.uk/ncs/FittingInternatl.htm
October 2nd, 2013, 8:01 pm
Make sure the tag at the top of the rear window gets properly located in the slot in the crossmember.
The boot corner pieces can be a pain in the arse, since the screws often seize or are rounded.
Russ is bob-on about leaving the screws on the outside.
Other than that, it's two 8mm bolts. Do 'em loosely at first, then shut the roof and fit the bootlid. With the back seat out, you can then tighten them in the right place.
October 4th, 2013, 1:53 pm
5mm setscrews? ;)
October 4th, 2013, 4:03 pm
Thanks everyone! :D
1988 2CV Special
1969 Singer Chamois
October 4th, 2013, 4:22 pm
