Chassis question
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=5001
Page 1 of 1
Author:  smyth602 [ September 18th, 2013, 11:47 pm ]
Post subject:  Chassis question
I've been driving my mum's 1970 dyane for the last couple of weeks while the acad is getting some much needed tlc. Definately since i last drove it, but even over the last couple of weeks i've noticed the steering is getting a bit heavier, the doors don't quite shut as well as they used to and the (rod-operated) throttle is getting sticky. Also, both inner wings are suddenly catching on the driveshafts on bumps.
All these problems get worse when one or two passengers get in. Am i right in thinking the chassis is starting to bend and therefore is on its way out?
Author:  lpgo [ September 18th, 2013, 11:53 pm ]
Post subject:  Re: Chassis question
Well you've got all the ingredients here, so I guess so, take a good look at the chassis.....
Author:  ken [ September 19th, 2013, 12:31 am ]
Or the lower bulkhead/toe board is on the way out, which could give similar symptoms.
Is the steering column still (fairly) central in the hole through the bulkhead?
Author:  smyth602 [ September 19th, 2013, 12:47 am ]
I'll have a look in the morning. i do know it doesn't self-centre whilst cornering if you let go... :/
Author:  samfieldhouse [ September 19th, 2013, 1:25 am ]
When my bulkhead went, my D*lly got to the point where the doors would open on corners... :lol:
