Page 1 of 1
[ 7 posts ] |
Oil pipe on the cylinder heads.
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
It seems Bonaparts now longer trade? Has anybody a solution for flexible pipes for the cylinder head feeds? Cheers Peter
| May 29th, 2022, 2:32 pm |
Roger V
 Re: Oil pipe on the cylinder heads.
i did think of doing that if/when i add a turbo. Had no idea where to look for them. I would imagine some sort of hydraulic pipe making company!
| May 31st, 2022, 7:49 pm |
Jonathan
| June 1st, 2022, 12:03 am |
subarupete
Hi, Jonathan, Yes those bits, but in flexible versions, for Off-Road or Raid.
Cheers Peter
| June 1st, 2022, 10:20 am |
Roger V
I suspect the tricky bit is finding the M7 banjo to fit onto pipe. Could M6 be drilled out? 90 psi and oil proof flexible pipe as well. Not forgetting, optional take off for turbo oil feed of course
| June 1st, 2022, 11:10 am |
Roger V
perhaps tap out to M8 and then M8 bolts an banjos should be easy to find
| June 1st, 2022, 11:21 am |
subarupete
| June 2nd, 2022, 1:18 pm |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 220 guests |
