View unanswered posts | View active topics It is currently May 1st, 2026, 11:29 pm
Reply to topic  [ 5 posts ]
 Chassis question
Haggis Muncher
Post Chassis question
I've been driving my mum's 1970 dyane for the last couple of weeks while the acad is getting some much needed tlc. Definately since i last drove it, but even over the last couple of weeks i've noticed the steering is getting a bit heavier, the doors don't quite shut as well as they used to and the (rod-operated) throttle is getting sticky. Also, both inner wings are suddenly catching on the driveshafts on bumps.
All these problems get worse when one or two passengers get in. Am i right in thinking the chassis is starting to bend and therefore is on its way out?
September 18th, 2013, 11:47 pm
Post Re: Chassis question
Well you've got all the ingredients here, so I guess so, take a good look at the chassis.....
September 18th, 2013, 11:53 pm
Or the lower bulkhead/toe board is on the way out, which could give similar symptoms.
Is the steering column still (fairly) central in the hole through the bulkhead?
September 19th, 2013, 12:31 am
Haggis Muncher
I'll have a look in the morning. i do know it doesn't self-centre whilst cornering if you let go... :/
September 19th, 2013, 12:47 am
When my bulkhead went, my D*lly got to the point where the doors would open on corners... :lol:
September 19th, 2013, 1:25 am
Users browsing this forum: No registered users and 112 guests
