View unanswered posts | View active topics It is currently May 1st, 2026, 2:52 pm
Reply to topic  [ 8 posts ]
 Bonnet hinge repair
Post Bonnet hinge repair
I'm about to commence replacement of my bonnet hinge and have one of these to fit Image
Before I cut the old one out and get to welding, is there anything worth considering doing while I'm at it? The panel inside looks to be in good shape. Is it worth taking the windscreen out or just mask and cover it?
Any pitfalls I should be aware of?
Your advice is much appreciated.
September 12th, 2013, 3:22 pm
Post Re: Bonnet hinge repair
yes the curve is slightly wrong and needs adjusting at the ends , the outside edges of the panel where they meet the top of the Apanel are usually filled with braize which can make welding tricky
pop holes in the lower flange to "Spot" weld it. The top bit needs careful welding to the panel below the screen as the original is thin and wax soaked so tends to blow holes
both the back and the front of the new panel needs the zinc buffed off or its a horrible sparkey blowey weld
bonnet hinge repair by Sean602, on Flickr
"spot" welding lower flange
copper spoons help when you get the odd burn through
tack and buff the top edge only do about 10mm max at a time dont weld again untill you can touch the metal with a bare hand
bonnet hinge by Sean602, on Flickr
or you can just tack and bodge with filler which isnt any quicker or easier and just means youll be back to it in a couple of years
September 12th, 2013, 4:41 pm
Thanks, a picture is worth a thousand words. I know what to look out for now.
September 12th, 2013, 5:00 pm
Just a thought but would it be a bad idea to either run a fillet of braze or lead load the hinge seam? Better than mastic surely?
September 14th, 2013, 10:01 am
The "copper spoons" look interesting. Can you explain how you use them?
September 14th, 2013, 10:06 am
"Some times the repair panel can be slightly bowed as well check before you fit it (bend it straight)cos a bowed one can still be fitted. But you will find the bonnet is then difficult to slide on.
September 14th, 2013, 10:51 pm
take the screen and rubber out otherwise you will get lumps of grinding dust and metal splatter all over it.
September 15th, 2013, 6:46 pm
"chill bars" takes some of the heat out the weld and stops the weld burning through - various shapes to fit the spaces behind the repair., press them on to the back where you are about to weld.Helps keep the repair and the original panel aligned. You can also get a hotter weld going that "wets" in to the metal so you don't get a cold bead sitting on top of the panel
You can even bridge large gaps start the weld on one side run it over the copper on to the next helps if the copper is nice and shiny stops it sticking.
September 18th, 2013, 3:05 pm
Users browsing this forum: No registered users and 73 guests
