Heat exchanger rattle
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4980
Page 1 of 1
Author:  Vosper2004 [ September 10th, 2013, 10:25 am ]
Post subject:  Heat exchanger rattle
Hi.
The driver's side heat exchanger has started to rattle, had a quick check and it's loose on the exhaust pipe. The car is in use at the moment so I can't have a good look. How is it fixed to the pipe?
Don
Author:  Taskos [ September 10th, 2013, 11:38 am ]
Post subject:  Re: Heat exchanger rattle
I'm afraid that pipe nad case are pressed together.
Author:  knightley [ September 10th, 2013, 11:42 am ]
They are spot welded, but often come apart due to corrosion. A dab of weld will cure it.
Author:  Vosper2004 [ September 11th, 2013, 8:48 am ]
Thanks for the replies. Doesn't look like it's a big problem then. Have to have a good look at the weekend.
Cheers
Don
