View unanswered posts | View active topics It is currently May 1st, 2026, 8:32 pm
Reply to topic  [ 4 posts ]
 Heat exchanger rattle
Post Heat exchanger rattle
Hi.
The driver's side heat exchanger has started to rattle, had a quick check and it's loose on the exhaust pipe. The car is in use at the moment so I can't have a good look. How is it fixed to the pipe?
Don
September 10th, 2013, 10:25 am
Post Re: Heat exchanger rattle
I'm afraid that pipe nad case are pressed together.
I've Been Wrong Before.
September 10th, 2013, 11:38 am
They are spot welded, but often come apart due to corrosion. A dab of weld will cure it.
John Jordan
September 10th, 2013, 11:42 am
Thanks for the replies. Doesn't look like it's a big problem then. Have to have a good look at the weekend.
Don
September 11th, 2013, 8:48 am
