 Hottest head
Post Hottest head
Hi legends,
Which of the two cylinder heads gets the hottest first or is more prone to overheat?
I will be fitting a Cylinder Head Temp sensor to one side so any suggestions of best location with enough meat to drill n tap equivalent of m8 10mm deep would be appreciated! :shock:
Harley
August 21st, 2013, 4:53 am
Post Re: Hottest head
Having watched double temp gauge whilst racing on different engines I can tell you they are the same.
Harley wrote:
Hi legends,
Harley
August 21st, 2013, 9:05 am
Harley is this of Interest?
Uses Thermocouple sensors can be placed on Cylinder head, Exhaust Manifold...
Can have an alarm....
DIY job..... @GasMark5 is going to improve on my bad coding :)
September 21st, 2013, 4:47 pm
we had an aircraft style analogue one which we took out as all the drivers kept coming in to tell us one head was hotter than the other
when it comes to drivers sometimes a start button and a great big IDIOT light is all you need ( like the pop crossers)
September 21st, 2013, 8:09 pm
What Sean said.
The more shit on the dash telling you what's wrong, the more shit you've got on your plate to worry about. It's a 2cv, there's so little to go wrong that when it does you'll know about it anyway. Chill the hell out, it's probably working fine.
September 21st, 2013, 8:23 pm
True, I just like making gizzomos.....
September 21st, 2013, 8:30 pm
Ooooh I like this I want one - Where do I get one?????
On my race car, on both engines, the temps are around the same, although the left one does always get to temp a little quicker than the other
September 21st, 2013, 8:33 pm
Its a homebuilt bit of kit, still being worked on.
September 21st, 2013, 8:39 pm
If you wanted tested on a race car let me know :mrgreen:
September 21st, 2013, 8:46 pm
Simon, thats fine......when it works reliably..... I will fettle an other one.
September 21st, 2013, 9:24 pm
