View unanswered posts | View active topics It is currently June 19th, 2026, 10:14 pm
 refitting gear-shift rod rubber
Post refitting gear-shift rod rubber
The teflon rubber in my gear-shift rod disintegrated out of unknown reason. Anybody out there with expertise in refitting a new one? I made up a rather temporary fix with some garden hose . . .
Ente gut - alles gut!
August 8th, 2013, 3:24 am
Profile YIM
Post Re: refitting gear-shift rod rubber
I understand they're a pain in the arse to replace.
Perhaps it's time to make the investment in a new assembly:
http://www.ecas2cvparts.co.uk/gear-change-slide-assembly-right-hand-drive-model-2cv6-only-stainless-steel-p-2036.html
If not, then I've got details somewhere of a chap here in Blighty that rebushes them. He did mine and it's perfect and was quite cheap.
August 8th, 2013, 8:23 am
I've seen one way to do this,one is cutting the the lever arm on the straight section close to the gearbox end,changing the bushes and then welding the lever back together. The only pitfall I foresee is the aliment of the shaft after,but not an insurmountable problem with a bit of thought. I would braze mine back together with a sleeve brazed over the joint,mainly as my welding is crap :-)
August 8th, 2013, 11:00 am
the guides can,t be replaced someone probably used oil to lube and they rotted away
talcum powder should have been used instead
August 8th, 2013, 10:35 pm
The guides can be replaced.
August 8th, 2013, 11:39 pm
how?
August 9th, 2013, 12:02 am
ayjay wrote:
how?
Luck
August 9th, 2013, 8:52 am
As said earlier, there's a fella in 2cvgb who does them, I sold him a load of slide assemblies.
August 9th, 2013, 9:04 am
Cut, remove, refit by collapsing rubber and bush. Refit and weld.
Voila
August 9th, 2013, 9:51 am
Voila
Ah as they say a picture is worth a thousand words :D
August 9th, 2013, 10:05 am
