| A Panel removal for cooling... http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4882 |
Page 1 of 3 |
| Author: | 4x4 SuperFinn [ July 1st, 2013, 12:59 pm ] |
| Post subject: | A Panel removal for cooling... |
Just wondering what the thoughts are to the removing of the A panel by the bonet to all allow better engine air flow/cooling? I've seen them removed or with the top section removed and wondered if it's worth doing? I'm going to Spain and wondered if its worth removing them as it hopefully will be HOT there. I've never bothered in the past but keep seeing more cars driving without them so there may be something in it... |
| Author: | 2CViking [ July 1st, 2013, 1:25 pm ] |
| Post subject: | Re: A Panel removal for cooling... |
On standard config. no. Raid config yes. If the chassis is fitted with full bash plate reducing air flow, then yes the more air removed from the engine compartment the better. |
| Author: | banjo [ July 1st, 2013, 2:16 pm ] |
![]() DSCF3535 by 2steamhorses(Bob), on Flickr I shot this at Salbris a neat way of getting more heat out of the engine bay,the boot pretty cool to!! |
| Author: | 4x4 SuperFinn [ July 1st, 2013, 3:36 pm ] |
banjo wrote: ![]() DSCF3535 by 2steamhorses(Bob), on Flickr I shot this at Salbris a neat way of getting more heat out of the engine bay,the boot pretty cool to!! That's a neat option. No need to stoere them in that safe place where you know you'll never find them again. |
| Author: | Sean [ July 1st, 2013, 5:47 pm ] |
nope its contra productive - watch the raindrops on your bonnet the next time its raining they form a T shape the airflow is at right angles to the A panels as its deflected off the sides by the windscreen the scoops then act to draw air out the engine bay. if you intend on grinding along a sand track in 1st and 2nd then yes it helps - bowling along a Spanish higway then keep em standerd and loose any under bonnet fluff that hangs down. PM sent BTW |
| Author: | ken [ July 1st, 2013, 7:28 pm ] |
Hope this is in addition to having heat escape tubes fitted and in good condition, not looking like something the dog has been chewing on for a few weeks... |
| Author: | lpgo [ July 1st, 2013, 7:33 pm ] |
Sean wrote: nope its contra productive - watch the raindrops on your bonnet the next time its raining they form a T shape the airflow is at right angles to the A panels as its deflected off the sides by the windscreen the scoops then act to draw air out the engine bay. if you intend on grinding along a sand track in 1st and 2nd then yes it helps - bowling along a Spanish higway then keep em standerd and loose any under bonnet fluff that hangs down. PM sent BTW So is this nothing more then a second scoop just like an old ripple bonnet?? I think this will work well especialy at high speed. I think this will actually make more sense then taking them out completly..... Here in Holland some guys bend them out even more; fixing them with a rubber bend from under the seat. fixing them towards the outer edge of the wing...... Anybody got a windtunnel in the backyard to test it???? |
| Author: | Sean [ July 1st, 2013, 11:48 pm ] |
geo - was talking about removing them completely |
| Author: | FDK683 [ July 2nd, 2013, 8:43 am ] |
I have removed them for a raid and refitted them when I returned home. How much extra cooling the removal offers im not sure. I would like to see some objective information. I removed them more because its one less pair of things to worry about, especially anticipating the likely hood of some maintenance along the way. In my mind the negative is the risk of police interest in a 'funny old car with panels missing'. Though, given another hot weather raid I would probably remove the panels again |
| Author: | richardmorris [ July 2nd, 2013, 11:13 am ] |
No ones mentioned the Venturi effect yet! |
| Page 1 of 3 | All times are UTC + 1 hour [ DST ] |
