| Acad rear brake drum nut http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4880 |
Page 1 of 1 |
| Author: | smyth602 [ June 29th, 2013, 11:43 pm ] |
| Post subject: | Acad rear brake drum nut |
This may be a stupid question, but is the nut which holds the acad rear drum on larger than on a 2cv? I assumed that as the bearings etc are larger the drum nut would be too, but I can't find anyone selling anything other than the 44mm drum nut... Hope someone can help! |
| Author: | lpgo [ June 30th, 2013, 12:41 am ] |
| Post subject: | Re: Acad rear brake drum nut |
Nut is the same, only outer diameter of bearing is diffrent |
| Author: | smyth602 [ June 30th, 2013, 12:48 am ] |
I feel very, very stupid now... :/ |
| Author: | lpgo [ June 30th, 2013, 9:59 am ] |
That's the forum for...... To feel stupid.......... I have it all the time.... |
| Author: | ken [ June 30th, 2013, 11:20 pm ] |
lpgo, I'm fairly sure that the inner bore of an Ami/AK/Acad wheel bearing is also larger than that of a 'standard' A series, even though the nut is the same... ken lpgo wrote: Nut is the same, only outer diameter of bearing is diffrent |
| Author: | lpgo [ July 1st, 2013, 12:35 am ] |
You see |
| Author: | callumbeveridge [ July 4th, 2013, 4:50 pm ] |
I have a rear brake adjusting tool which is too big to fit into the bearing on a standard 2cv rear drum. Therefore, I assumed that the inner diameter of the bearing on a van is bigger than the car. Is this not the case? Rgrds Callum |
