Page 1 of 1
[ 7 posts ] |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
 Acad rear brake drum nut
This may be a stupid question, but is the nut which holds the acad rear drum on larger than on a 2cv? I assumed that as the bearings etc are larger the drum nut would be too, but I can't find anyone selling anything other than the 44mm drum nut...
Hope someone can help!
| June 29th, 2013, 11:43 pm |
lpgo
 Re: Acad rear brake drum nut
Nut is the same, only outer diameter of bearing is diffrent
| June 30th, 2013, 12:41 am |
smyth602
Haggis Muncher
I feel very, very stupid now... :/
| June 30th, 2013, 12:48 am |
lpgo
That's the forum for...... To feel stupid.......... I have it all the time....
| June 30th, 2013, 9:59 am |
lpgo, I'm fairly sure that the inner bore of an Ami/AK/Acad wheel bearing is also larger than that of a 'standard' A series, even though the nut is the same... ken lpgo wrote: Nut is the same, only outer diameter of bearing is diffrent
| June 30th, 2013, 11:20 pm |
lpgo
| July 1st, 2013, 12:35 am |
callumbeveridge
Joined: January 12th, 2012, 3:17 pm Posts: 8 Location: Inverness
I have a rear brake adjusting tool which is too big to fit into the bearing on a standard 2cv rear drum. Therefore, I assumed that the inner diameter of the bearing on a van is bigger than the car.
Is this not the case?
Rgrds Callum
| July 4th, 2013, 4:50 pm |
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: No registered users and 203 guests |
