View unanswered posts | View active topics It is currently June 19th, 2026, 10:14 pm
Reply to topic  [ 3 posts ]
 Remote oil filter
Post Remote oil filter
I'm thinking of fitting a remote oil filter to my 425 Azam's engine, would it be best to break into the oil cooler feed pipe? is the pump up to it would a motorcycle type be preferable, I know its not original but can only be a good thing judging from the sludge in the sump on strip down :o
June 16th, 2013, 12:27 pm
Post Re: Remote oil filter
I don't know the 435cc engine but assume it doesn't have oil filter...
I understand that the way a 602 oil cooler works is that the circuit will bypass it if it is blocked, this would mean that by adding a remote filter inline with the oil cooler would not filter all the oil I suspect, but some is better than none!
I also believe that modern filters also have a bypass in the event they are blocked also.
[img]
http://www.pp-2cv.be/FR/News/Pic%20info ... %202cv.jpg[/img]
Hope that helps...
Harley
June 17th, 2013, 2:37 pm
June 17th, 2013, 4:10 pm
