View unanswered posts | View active topics It is currently June 19th, 2026, 10:13 pm
 Putting oil in the gearbox
Post Putting oil in the gearbox
How do I do it, the Haynes manual is not helpful. Should I drain out what is in there first? The Haynes manual does suggest a certain oil to stop noise, deffo need that!
Charlie is gone. Now 2CVless.
June 14th, 2013, 1:24 pm
Post Re: Putting oil in the gearbox
look at "gearbox oil" on this thread or you'll start a fight. A multigrade is fine, I use fully synth
drain is under the crownwheel - between the driveshafts underneath.
fill is on the side just above the exhaust. both plugs are 21mm af- sparkplug spanner size
drain and fill rather than just top up - takes just under a litre (90cl)
June 14th, 2013, 1:32 pm
It is important use oil without sulphur or chlorine. Becouse there are some materials used in the gearbox that can damage.
At the duch forum they discover this oil are without the sulphur and chlorine:
Red Line MTL (70W80 GL-4) = synthetisch
Red Line MT-90 (75W90 GL-4) = synthetisch
Quaker State High Performance 80W-90
Quaker State Synquest GL5 75W-90 = syntetisch
Millers EP 80 GL 4
Shell Spirax GX (GL-4)
Texaco Multigear MTF 75W/80W (GL-4)
There are more ofcourse
2cv6,5
June 14th, 2013, 1:48 pm
The easiest way I fill up is to measure out 90cl in a jar. Jack up the car on the plug side and use long pipe with funnel on the top and fill slowly until all gone. Tighten plug and lower car.
June 14th, 2013, 2:22 pm
I know, I know, I know
NOW
I learnt the hard way :(
June 14th, 2013, 2:23 pm
I'm not sure if 2cv differentials are, but to quote Redline's website,
"MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears"
http://www.redlineoil.com/Products.aspx?pcid=7
June 15th, 2013, 4:25 am
they arent
June 15th, 2013, 9:36 am
I normally buy a litre, chuck 100ml away and thrn its all measurerd in the bottle so you can stick the oil in easy
June 15th, 2013, 11:02 am
+1
June 15th, 2013, 11:16 am
NOW
Not just me then :lol: :lol: :lol: :lol:
June 15th, 2013, 12:26 pm
Users browsing this forum: No registered users and 202 guests
