Bulbs
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4802
Page 1 of 1
Author:  Toy [ May 28th, 2013, 8:47 pm ]
Post subject:  Bulbs
Are there any replacement bulbs ie led or the like for the instrument panel on a 2cv that will let you see it
Author:  banjo [ May 28th, 2013, 9:12 pm ]
Post subject:  Re: Bulbs
There is got mine off ebay on my 1986 model the speedo is a wedge ype rather that a the usual bayonet fitting.As in the following link :P
http://www.ebay.co.uk/itm/2-x-LED-Side- ... 2c6a9c301f
They give a very white light without the heat you get with ordinary bulbs mine have been in now for 4 years.
Author:  Toy [ May 28th, 2013, 9:25 pm ]
Dont look like they will fit in a standard bulb holder ? Have you got to change anything apart from the bulb?
Author:  banjo [ May 28th, 2013, 9:43 pm ]
The wedge type are whats fitted to my 2cv and no they wont fit a the more normal type holder,check which you have. There is no other change needed just replace the bulb or in this case just replace the bulb holder to take these, but I have also used the normal fitting with an LED replacement. :) Well worth doing as the bright white light makes your speedo very clear,
Here is a link to replacement bulb holderhttp://www.ebay.co.uk/itm/501-W5W ... 2a2ccf44e9
Author:  Toy [ May 28th, 2013, 11:42 pm ]
Thanks banjo
Author:  nodmoz [ May 29th, 2013, 10:30 am ]
I use these guys - http://www.fizzmo.co.uk/
Reasonable prices, never messed me about, and they work well.
