Reply to topic  [ 6 posts ]
 Bulbs
Post Bulbs
Are there any replacement bulbs ie led or the like for the instrument panel on a 2cv that will let you see it
May 28th, 2013, 8:47 pm
Post Re: Bulbs
There is got mine off ebay on my 1986 model the speedo is a wedge ype rather that a the usual bayonet fitting.As in the following link :P
http://www.ebay.co.uk/itm/2-x-LED-Side- ... 2c6a9c301f
They give a very white light without the heat you get with ordinary bulbs mine have been in now for 4 years.
May 28th, 2013, 9:12 pm
Post Re: Bulbs
Dont look like they will fit in a standard bulb holder ? Have you got to change anything apart from the bulb?
May 28th, 2013, 9:25 pm
Post Re: Bulbs
The wedge type are whats fitted to my 2cv and no they wont fit a the more normal type holder,check which you have. There is no other change needed just replace the bulb or in this case just replace the bulb holder to take these, but I have also used the normal fitting with an LED replacement. :) Well worth doing as the bright white light makes your speedo very clear,
Here is a link to replacement bulb holderhttp://www.ebay.co.uk/itm/501-W5W ... 2a2ccf44e9
May 28th, 2013, 9:43 pm
Post Re: Bulbs
Thanks banjo
May 28th, 2013, 11:42 pm
scared of the dark
Post Re: Bulbs
I use these guys - http://www.fizzmo.co.uk/
Reasonable prices, never messed me about, and they work well.
Some previous cars:
May 29th, 2013, 10:30 am
