Reply to topic  [ 2 posts ]
 King Pin Swap
gym bunny
Post King Pin Swap
Standard arms, lowered suspension or just lazy? You may need this eventually if you dont grease regularly!
Its not a hard job with the propper drift set, a very large vice and a big hammer!
For those of you who have lost, damaged etc the easy how to instructions that came with the propper (Ecas) drift set then I have attached that as I laminated mine after it nearly went bye byes!
Other tricks such as increasing the dome of the top cap using a large ball bearing and socket etc make fitting much easier!
1299cc FTW
January 6th, 2009, 3:29 pm
Post Re: King Pin Swap
I've got a homemade press to push out old pins and fit new ones. Years old now, but works fine. Much less brutal than drifting out pins. Available to any mates if needed.
January 29th, 2009, 1:00 am
