Wireing problems?
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4796
Page 1 of 3
Author:  Hannahman58 [ May 27th, 2013, 3:40 pm ]
Post subject:  Wireing problems?
My rebuild is at the stage now where the wireing needs installing, but being new to 2cv, I'm gob struck at the task ahead :D
Every other wire is green?
Why didnt they use different coloured wires Iike the rest of the world?
Nothing has been labeled, so I'm at the mercy of the Haynes manual which confuses me no end!
For example, looking for a connection for the brake fluid check switch, ( might not be correct, but just using this as an example) it says I should be looking for a brown and a clear connection, but I can find a green wire with a brown connection and a grey wire with a brown connection? Which one is which?
What is what?
Also, several of the connections ask for a Bl, which is blue, but in the dozens of connections I have , there's only one blue spade connection! Dozens of Violet, but only one blue!
My plan of attack is to install the wiring, connect what falls and fits in that area, connect the battery and very carefully switch on, see what works, and fix what doesn't!
Any advice for me would be great
Author:  Harley [ May 27th, 2013, 5:13 pm ]
Post subject:  Re: Wireing problems?
Buy a half decent voltmeter, one that has a clear AUDIBLE continuity tester, cheap ones you can hardly hear...
this means you can set it to continuity and probe one end of the wire and the others, or fuse box to see where it ends/runs to. I found it priceless with my rebuild! given I had a few extra wires though, I still use it a lot.
It was 3 1/2 years between pulling it all apart then purring it back together so of course I didn't label anything cause it seems so easy when you disassemble it, at the time...
I also scanned old pics I had to see how the loom lay, that was the first battle...
but this would be more useful on a standard 2cv...
Author:  Hannahman58 [ May 27th, 2013, 7:05 pm ]
Thanks for the reply,
Don't you think for such a simple car with so few"gadgets" there's tons of wires?
I've re wired several Morris Minors, and found it simple, every wire has a colour, every colour has a destination,
Citroen? Every colour is green or grey!
I've no problem with the wires to the rear of the car, they have all lined up and colours matched up.
Just see how we go!
Paul
Author:  sbach [ May 27th, 2013, 9:34 pm ]
Hi Paul,
Do the big wires first, ignition, starter, voltage regulator and alternator. There's a fat yellow one to start with at the starter motor.Then photograph it and post it here. The mysteries of the other wires will become apparent. I'll send some photos during the week.
Author:  Hannahman58 [ May 27th, 2013, 9:39 pm ]
sbach wrote:
Hi Paul,
Thanks for your assistance!
Author:  sbach [ May 27th, 2013, 10:51 pm ]
Tim2cv has a post called 'mystery wires' He has posted photos that might help.
Look at Page 66.
Author:  Neil [ May 28th, 2013, 11:31 am ]
Look at Page 66.
viewtopic.php?f=7&t=191
Author:  Hannahman58 [ May 28th, 2013, 1:48 pm ]
Harley, in your first picture, whats all the wires on the drivers side?
I only seem to have the right hand side harness?
Author:  ayjay [ May 28th, 2013, 3:03 pm ]
hi hannaman the wires have a coloured sleeve at each connection-- that makes it a bit easyer to i/d the wires
Author:  Harley [ May 28th, 2013, 3:23 pm ]
Thats the EFI wiring loom, disregard that!
Page 1 of 3 All times are UTC + 1 hour [ DST ]
