2CViking
 Gear Box
2CViking wrote: Not Sammie this time but Mister Kelso ended his National at 2CViking fixing the gear box. The garage guys at the meeting had a try removing the lid and rear cover, only to closed it again doing nothing + missing the selector fork ring unscrewing. They did the 2 rear nuts forgetting locking the speedo nut The 2-3 sliding pinion moved forward rubbing on the back of the input shaft gear, making a terrible noise. The selector ring nearly came off the thread but luckily didn't. I may find other things as the box is stripped completely Well I did find other things. I guess the 2 hour rebuilt job is down the drain  It just show that one can NEVER do a quick repair unless prepared to accept a compromised box.
| May 14th, 2013, 1:25 pm |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
 Re: Gear Box
My dad made me shake my head in absolute wonder a few weeks back when, upon trying to decide if a gearbox was 'good', he sat it on the ground, moved the selector to each position, and when it didn't explode into a million parts declared 'That's a good one, that is..." I'm far from an expert mechanic, and gearboxes are mysterious casings full of teeth and oil to me, but even I knew there was slightly more to it than that
| May 14th, 2013, 1:52 pm |
 Re: Gear Box
Viking, guess the technical term for that particular gearbox is ' totally sh@gged'? Picked up a scrapper a few weeks back and the owner threw a couple of extra gearboxes into the trailer as we were leaving. So far, I've only had time for a quick look at one of them and the rear main bearing on that had just one ball bearing left in the cage. Some folk never know when to give up, pressing on regardless of the sounds of protest from the machinery, until the big bang happens and all that's left is scrap... ken
| May 14th, 2013, 3:35 pm |
2CViking
 Re: Gear Box
ken wrote: Viking, guess the technical term for that particular gearbox is ' totally sh@gged'? Picked up a scrapper a few weeks back and the owner threw a couple of extra gearboxes into the trailer as we were leaving. So far, I've only had time for a quick look at one of them and the rear main bearing on that had just one ball bearing left in the cage. Some folk never know when to give up, pressing on regardless of the sounds of protest from the machinery, until the big bang happens and all that's left is scrap... ken It is FUCKED but Mr Kelso accepted a rebuilt. Should be back on its feet Wednesday afternoon. You should have seen what was presented to me at the French National. One box running for hundreds of clicks WITHOUT OIL.
| May 14th, 2013, 7:29 pm |
Harley
Joined: May 3rd, 2009, 11:40 am Posts: 816 Location: Melbourne, Australia.
 Re: Gear Box
2CViking wrote: It just show that one can NEVER do a quicky unless prepared to accept a compromised box. All the box i've encounter as been compromised, I've never been the first one at it... ken wrote: guess the technical term for that particular box is ' totally sh@gged'? until the big bang happens and all that's left is scrap... Harley
samfieldhouse wrote: It is M9 for the shocks yes, the rest I'll check when next i'm underneath her. Ironically, this will be valentines day.
| May 14th, 2013, 7:33 pm |
samfieldhouse
 Re: Gear Box
It is exactly a year since you rescued me Peter!
| May 15th, 2013, 1:42 pm |
2CViking
 Re: Gear Box
samfieldhouse wrote: It is exactly a year since you rescued me Peter! Gear box still good? Happy Pommes packing to go home but not without coffee and french bread A bit worries about the weight the gear box needs to pull
| May 17th, 2013, 7:03 pm |
2CViking
 Re: Gear Box
Tell me again that ''the final drive'' is not necessary to consider when restoring the famous 2 hour rebuilt. This box was handed to me at the French national but didn't have time to look at it. Did today, oh boy is it buggered. Metal everywhere. I'm restoring this box (maybe a little more than 2 hours)
| June 3rd, 2013, 7:12 pm |
 Re: Gear Box
Viking, is there anything usable/restorable left in that gearbox? It looks worse than the last one which you photographed and that was quite a mess... ken
| June 3rd, 2013, 11:31 pm |
2CViking
 Re: Gear Box
More and more boxes are coming in for work. It just shows that ignoring early signs (noises) is something that comes back later to bite your wallet. This box is sadly retiring to parts only, whats left of it. Luckily I have plenty of early 425 boxes but it is getting to a 3 : 1 ratio to produce something usable. Yesterday a 2cv4 came in being rejected at CT (brakes etc) The owner want nothing done except getting it back through CT with a minimum of repairs (did one rear brake side only) The gear box is just about to explode, input shaft bearing collapsed. Do you thing the owner cares NO. ''I'll come back maybe one day. Surely it should last a little longer''  Ya right the entire box will be destroyed and he will pay even more. I shouldn't write this but I hope it will fuck up on the way to the second visit
| June 4th, 2013, 8:45 am |
Users browsing this forum: No registered users and 228 guests |
