Reply to topic  [ 7 posts ]
 Corroded fuse terminals
Post Corroded fuse terminals
Hi
I've had occasional electrical problems due to the fuse terminals being corroded. The plating has worn off. A scrape with a screwdriver cures the problem for a while.
Looks a simple enough job to replace these.
Checked with Ecas but they are not available except on a new wiring loom. Apparently it's not a common problem.
Does anyone know if they are available anywhere?
Don
Bristol UK
April 25th, 2013, 10:14 am
Post Re: Corroded fuse terminals
I guess this is on a late model 2CV...
If so, have you tried coating the terminals with petroleum jelly/vaseline after cleaning them?
A chainsaw file of similar diameter to the fuse is handy for cleaning the contact surfaces, removing one terminal at a time from the holder for access.
Vosper2004 wrote:
Hi
Don
Bristol UK
April 25th, 2013, 10:32 am
Hi Ken.
I'm giving them all a good scrape now.
The car is 1975 but I suspect the only thing that is that year is the log book.
Don
April 25th, 2013, 10:57 am
Changed mine to blade fuse holder, better protection for the elements with the added bonus that blade fuses are easier to find when you need them.
April 25th, 2013, 1:52 pm
Hi Jonathon,
Thanks for the reply.
A new fusebox is an option that I am considering.
The latest problem appears to have been the connection on the ignition switch.
However I've spent a worthwhile hour or two checking and cleaning connections.
I had search around and see that a German supplier has a similar looking fusebox for the traditional fuses with blade terminals.
Don
April 25th, 2013, 3:51 pm
Different type 'boxes here.....
http://www.autoelectricsupplies.co.uk/product_list/63
April 25th, 2013, 11:12 pm
I agree, I rewired mine starting with a modern fusebox. And use the supplier Jon mentions too :)
April 26th, 2013, 12:53 am
