View unanswered posts | View active topics It is currently June 19th, 2026, 2:10 pm
Reply to topic  [ 9 posts ]
 Single system brake master cylinder (Drummer).
Post Single system brake master cylinder (Drummer).
This job is starting to get on my wick now. If I'm not too busy with real life its raining, and if its not raining things are seized!
First question:
The reservoir, does it unscrew by hand or do I need a spanner that is bigger than all the ones I seem to have?
Please help, lots of love Louise.
June 7th, 2009, 12:40 pm
Post Re: Single system brake master cylinder (Drummer).
Glass, metal or plastic reservoir. Regardless, spanner is needed. Maybe a photo?
June 7th, 2009, 12:58 pm
plastic, righto, 19mm or 20mm? Thanks!
June 7th, 2009, 1:04 pm
got it, do I just undo it now, because its not budging :?
June 7th, 2009, 1:11 pm
If it is the tall light yellow plastic reservoir, you need a skinny 21 mm.
Standard 21 mm open ended spanners are too thick to slide in underneath.
They come off very easy, when you have the right spanner.
June 7th, 2009, 1:19 pm
Just done it yay! Thanks for the advice, super quick!
Reassembly just the reverse right?
June 7th, 2009, 1:45 pm
Yes,
not forgetting that copper sealing washer, of course...
June 7th, 2009, 1:53 pm
Thanks Ken, also thanks for the battery tray tip, I Love LHD!
June 7th, 2009, 3:26 pm
The pedal seems rock solid now... might have to test it in a sec, if I can get the damn thing started!
June 7th, 2009, 3:31 pm
Users browsing this forum: No registered users and 196 guests
