View unanswered posts | View active topics It is currently May 2nd, 2026, 12:51 am
Reply to topic  [ 5 posts ]
 Checking bearing crush?
Post Checking bearing crush?
How important is it to check the bearing crush, using a Plastigage, during assembly?
Or can I just torque the case up to specifications...
It's a Visa motor with new camshaft and crank bearing shells.
Cheers much!
March 26th, 2013, 8:44 am
Post Re: Checking bearing crush?
Not possible on closed bearings. Before torquing the full amount, the crank MUST turn by hand without any obstruction. Do the 4 main bolts or nuts to full torque and feel again. Measure for vertical play front and rear + side play front and rear. Put the fan hub on and pull/push to feel the free movement or measure before clamping the engine together. You may find anything from 0,35 mm and upwards. 0,50 is still acceptable beyond that would be too much (matching your drive style :mrgreen: )
March 26th, 2013, 9:45 am
Cheers much!
NEW, where and how much. I have several cranks in good working order but the front cage is fucked. Can't find parts of anybody interested in replacing the bearing?
March 26th, 2013, 9:49 am
Firstly you have to speak French. Or have a Beautiful French wife, so I guess you pass ;-)
41euro a set for Visa engine, one large one small. I got enough for 2 engines.
You already know the contact! I'll send u an email.
Xx
March 26th, 2013, 1:01 pm
Xx
Beautiful or not, it doesn't matter. Turn them upside down and have a look. They are all the same :mrgreen:
What email?
March 26th, 2013, 1:24 pm
