Reply to topic  [ 6 posts ]
 Crank timing gear
Post Crank timing gear
Anyone removed this gear?
I had a 2cv in with a serious knocking. It turned out the the front aluminium cage (behind the timing gear had moved 20 mm around. Someone placed the bearing wrong and clamped the 2 engine blocks together with the bearing in the wrong place. Eventually the a 20 mm long groove appeared allowing the bearing to turn and swift back.
I would like to remove the timing gear but can't remember if it is possible? The crank is too good to bin
March 13th, 2013, 1:19 pm
Post Re: Crank timing gear
Yes it is possible, but I don't know how (press I guess), I know VGS in Belgium is doing that it seems that the toothwheel can be as much as 6 degrees of (from the Citroen fabric), making your engine run like crap, valvetiming is of then......
picture of there website.... camshaft without camwheel
March 13th, 2013, 1:24 pm
Thanks mate. What about the crank?
March 13th, 2013, 1:26 pm
Take a look at there site (several pics) http://www.vgs2cv.be/index.php/en/2cv-visa-crankshaft.html
March 13th, 2013, 1:31 pm
Crank can be done too Peter. For similar reasons I got main bearings replaced by Burton on a crank the other day.
March 14th, 2013, 8:24 pm
Ya I've seen the crank press that Burton dug out in northern Africa not long ago. It is a monster press, supposedly used by Citroen maybe in Algeria
March 14th, 2013, 9:50 pm
