bobh
 Speedo error
1963 Fourgonnette. I have done an engine / gearbox swap out from the 425 to 605 with a 'new' drummer gearbox. All gone Ok including 6 to 12 volt conversion. The Original speedo now reads about 17kph slow (about 10mph?). Any ideas ?
| May 16th, 2013, 9:40 pm |
 Re: Speedo error
go 10mph faster?
| May 16th, 2013, 9:54 pm |
Mark350
Joined: February 6th, 2010, 12:22 pm Posts: 311 Location: Herefordshire
 Re: Speedo error
Similar here - my 350 now has a disc brake gearbox and gives the following readings: 40kph (which should be 25mph) is actually just under 30mph (in fact, I use the needle's position at ' just past the 40' as 30mph) 100kph (supposedly 62mph) is actually around 68mph on the satnav It's about 10% out - you could mark the speedo to record the new readings or just try to remember it ( I've opted for the latter) although I did read somewhere that a correctly working speedo may be part of a future MOT, so we may have to actually do something to correct it at some point...
_________________ .............................................. ~ deliver me in a black-winged bird ~
| May 17th, 2013, 3:32 am |
Jonathan
 Re: Speedo error
Mark350 wrote: although I did read somewhere that a correctly working speedo may be part of a future MOT, so we may have to actually do something to correct it at some point...  I doubt it would affect a vehicle of that age if they did introduce such a thing.
| May 17th, 2013, 11:16 am |
nodmoz
scared of the dark
Joined: December 11th, 2008, 11:36 pm Posts: 197 Location: Staffs, UK
 Re: Speedo error
Gaffa over it. Problems go away!
 Some previous cars: 1992 BX17TZD - leaked the green stuff. 1996 Xantia - some scum set it on fire. 1996 Xantia - never lend your car to someone, they may write it off.
| May 17th, 2013, 4:06 pm |
J-dub
 Re: Speedo error
I adjusted mine by taking the face (glass) off, driving at 30mph (sat nav) and then stuck the needle back on at 30mph. Worked a treat
| May 18th, 2013, 8:33 am |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
 Re: Speedo error
Great,but sat navs read slower don't they?
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| May 18th, 2013, 9:05 am |
J-dub
 Re: Speedo error
Yes but by the time you dont quite get it on perfectly cos yoir driving its ok. Also sat navs read fine its cars read faster
| May 18th, 2013, 9:08 am |
dave 411
 Re: Speedo error
 oh
| May 18th, 2013, 9:20 am |
smyth602
Haggis Muncher
Joined: September 13th, 2012, 7:38 pm Posts: 571 Location: Denny, Scotland
 Re: Speedo error
No, sat nav systems tend to be bang on with speed.
Speedos on modern cars under-read, usually due to the manufacturer playing it safe, but with the 30-odd years of wear we'll all have in the mechanisms, along with plenty of engine and gearbox changes thrown into the mix its anyone's guess as to just how accurate our 2cv speedos are...
| May 18th, 2013, 11:39 am |
Users browsing this forum: No registered users and 213 guests |
