 Budget Question
Post Budget Question
Replace the rings or new Barrels with pistons?
Pics from fuel pump side of engine
Barrel has no lip/ridge at the top
February 20th, 2013, 5:32 pm
Post Re: Budget Question
Clean it, check the gaps on pistons and if they are OK, change only piston rings.
www.2cvkeza.com
February 20th, 2013, 8:06 pm
Pete,
as well as checking the end gaps, also check the side clearance of the top two rings in their grooves, which should not be more than about 5 thou.
Judging by the amount of varnish and carbon below the oil control ring. there's been a fair amount of blowby going on...
February 20th, 2013, 8:22 pm
Someones been a bit enthusiastic with the 80 grit
I always give the top of the barrel a qick spin with the hone to highlight where the wear is. Most wear occurs in the top 25 mm of the swept area. As there isn't much left of the honing I'd say that they are probably on the worn side but its almost impossible to tell in a photo.
using your fingers holding the abrasive they follow the contours as they are soft. The stones on the hone buff the high points to a grey finish but the worn areas have the polished brownish finish
February 20th, 2013, 8:48 pm
rebore& new pistons otherwise its half a job
i,m no expert though
February 20th, 2013, 9:50 pm
given the relative cost of a new P&B set that's good advice
February 20th, 2013, 9:54 pm
That's what I thought too. Actually, when I saw the pics I thought of hand honing :lol:
February 20th, 2013, 10:06 pm
Rebore?
Only if you can manage to track down a set of those 0.5mm oversize Kolbenschmidt pistons... :lol:
February 20th, 2013, 10:50 pm
Id assumed that Ayjay meant barrel and piston set I found a set of oversize pistons got barrels machined to match to them, just need to source a ring set and its good to go! was it cheaper than a full set? If id had to pay for the pistons then no
February 20th, 2013, 11:50 pm
by the looks of the barells and those pistons---
are well worn!(cream crackered infact)
any piston blow by is no good
it gets the oil all dirty and crank case pressure too
February 21st, 2013, 12:16 am
