 minimum weight of flywheel
Post minimum weight of flywheel
must have made ​​a new flywheel for my green 2cv when I need to use the flywheel to another project.
How much can I get of it???
has removed about. 1 kg. from the old and the new should preferably be something lighter,
I have no problems now with idle or bad start.
I know that the mass must be removed from the outer edge
Image 2cv special 0,6Tii
viewtopic.php?f=5&t=1610
January 25th, 2013, 1:09 pm
Post Re: minimum weight of flywheel
You can make it as light as possible, however idling at (very) low rpm will be a disaster, when it misses a beat then your engine will stop at once.
Every rpm above 1250 will be fine I guess...
Bring down the advance when starting the engine. to overcome the lack of weight (swing) of the flywheel
January 25th, 2013, 1:16 pm
1 2 flywheel lpgo???
January 25th, 2013, 1:51 pm
Those on the picture, how many kg. ??
January 25th, 2013, 3:19 pm
@ JW it is getting boring........... 1-2-boring.....
@ Lars, found this pic with a quick serge during my lunch-brake, maybee they still exist and can you give them a mail/call????
January 25th, 2013, 5:35 pm
1-2-never a problem at idle with light flywheel big trouble when you rev the nuts off them - they are prone to "handgrenading"
NES is Geoff Archer and yes he is still around and possibly lurking on this forum
January 25th, 2013, 10:22 pm
I have googlet, fandt this on snail
right heres some weights
our alloy slotted 1.78kg
our steel slotted 2.37kg
std late type 6.45kg
std coil spring type 10.12kg
hope that answers a question
February 9th, 2013, 10:10 am
Just reminded, once I have fitted a 425 flywheel to a 602, this is doable. You only need to drill the 5 nutholes that they fit, theres body enough tot do that...... Put a socket 24 (or something which fits tight) through both the holes of the flywheel the little pin will help you to line up and drill the holes to the 602 pattern......
Instant weight loss......
The engine must still lay arround somewhere in my garage...
Nice to see a Dutch guy and a Dannish guy try to write English.....
February 9th, 2013, 11:36 am
Puts me too shame english is better than mine
February 9th, 2013, 12:17 pm
This must be the only place where native English speakers post messages that are barely legible but those who use English as a second or third language can manage to post messages which are spelt and punctuated perfectly. We are, as a nation, fucked.
February 9th, 2013, 2:09 pm
Users browsing this forum: No registered users and 119 guests
