Page 1 of 1
[ 5 posts ] |
Tripyrenees
Joined: December 17th, 2012, 10:03 pm Posts: 966 Location: Luscan, Pyrenees, FRANCE
 Ignition Light
Should this be glowing RED all the time. Since I have had the car (about 3 weeks) this light has never gone off (other than when I turn off the ignition). When the engine is running it is still on.
Now, I have just had problems with my battery going low, I put it down to lots of work on the lights without running the engine. But when I took it out for a spin and to get some petrol, the headlights (first time I have used them) were very very very dim (first time in a 6 volt but I have just put in new white bulbs) and when I came to restart, nothing at all.
So do I have an issue with my recharging circuit i.e. should the RED light go off when I am driving. Would this be a dynamo issue ??
Cheers Ian
_________________ https://www.facebook.com/GNGLuscan
| January 3rd, 2013, 9:34 pm |
Chris 2cv
Joined: February 2nd, 2009, 10:25 pm Posts: 293 Location: Hampshire
 Re: Ignition Light
Are you sure it is not Oil pressure light?
| January 3rd, 2013, 10:09 pm |
 Re: Ignition Light
Ian, on an older A series equipped with a crankshaft mounted dynamo, the red light will be a 'lack of charge' warning light. Your van does have a 425cc engine, not a 435cc, iirc? ken
| January 3rd, 2013, 10:17 pm |
Tripyrenees
 Re: Ignition Light
Yep, it is 425cc
So would this be lack of charge by the Dynamo?
| January 3rd, 2013, 10:36 pm |
 Re: Ignition Light
Unfortunately, it will be. Check the dynamo brushes first, as that's the easiest option. ken Tripyrenees wrote: Yep, it is 425cc
| January 3rd, 2013, 11:15 pm |
Page 1 of 1
[ 5 posts ] |
Users browsing this forum: No registered users and 162 guests |
