 Engine turns - but no compression
Post Engine turns - but no compression
I have a spare engine that turns over ridiculously easily with absolutely no compression whatsoever. Does this mean that the valves are stuck open? Or does it indicate something else?
January 3rd, 2013, 9:31 pm
Post Re: Engine turns - but no compression
Damaged piston maybe broken rings. Is it both sides?
January 3rd, 2013, 9:35 pm
Not sure, but winding the engine on the crank just makes everything whirr around, with no resistance at all.
January 3rd, 2013, 9:41 pm
Place your finger on (not in) the spark plug hole, turn the engine and feel if any compression and vacuum
January 3rd, 2013, 10:57 pm
+1 to 2cv viking
also remove the tappitt covers to see if the valves are operating correctly
January 3rd, 2013, 11:31 pm
might not have pistons in it, Ive got one like that.
January 4th, 2013, 12:09 am
Wouldn't the rods be crashing around when u turned it over if there were no pistons...?
Mike
January 4th, 2013, 12:11 am
Trying to diagnose it from memory. It's at the back of a tractor shed with limited access and I'm struggling to raise enthusiasm to move things and get my hands dirty. Suspect I might be suffering from Post-Christmas Lethargy Syndrome, or something equally debilitating.
January 4th, 2013, 12:13 am
Did you see if there are spark-plugs in it!!!!!!!! otherwise you got these symptoms...
Sorry just checking.....
January 4th, 2013, 1:14 am
xxxxx
January 4th, 2013, 1:37 am
