 the pic regarding the kingpin mod
Post the pic regarding the kingpin mod
ive searched high and low here , but can,t find the link/page regarding that exellant kingpin mod (with the threaded rod through the centre of the pin)
ive just got my printer back online after buying an installation cd on ebay :P and would like to print the info& diagram off
sorry to be a pain! :oops:
andy
December 12th, 2012, 11:23 pm
Post Re: the pic regarding the kingpin mod
these http://www.pp-2cv.be/FR/News/KitPivot.htm
December 13th, 2012, 12:27 pm
Was there a homemade version of that in an edition of 2CVGB news 'recently'? Recently could be any time in the last 2 years, it rings a bell from somewhere.
December 13th, 2012, 2:03 pm
thanks subarupete thats not the same one but its fine!
andy, :D
December 13th, 2012, 3:08 pm
What's the point of that mod? Just seat your welch plug properly. :)
John Jordan
December 13th, 2012, 4:08 pm
Like
December 13th, 2012, 5:01 pm
it stops the welch plug from popping out when you pump the grease in knightly,
--sort of anchores it down :) and increases the life of the k, pin/ bushes
if the welch plug is leaky theres no pressure when you pump the grease in is just comes out at the top and doesn,t get to the bush/kingpin faces very much
dunno what others think on the subject as i,m no expert :?
December 13th, 2012, 11:19 pm
2CViking wrote:
i recently did my kingpins knightly, bought the whole kit
the welch plugs seated fine
i boinched it in the centre of its dome to expand it and punched the remaining edging around it, but it had been replaced a few times previously
the edge of the hole on one side was mullered when it came to pumping the grease in is just leaked
Like
December 13th, 2012, 11:28 pm
I tried this mod the last time I did my kingpins and abandoned it in the end and went back to a welch plug. I tried O-rings, fibre washers, even epoxy leak sealer but none were a match for my Wanner grease gun which forced the grease through the washer rather than retaining it. The welch plug, although not sealing perfectly, was far superior. To my mind the whole point of the mod is to stop the grease escaping and so forcing it into both top and bottom bushes.
I think the original home grown mod you are thinking of is by Mike Phelan. It may well have appeared in 2CVGB mag but he posted it on the Yahoo 2CV List as well, which is where I came across it.
John
December 14th, 2012, 12:21 am
those wanner grease guns are good john :D
December 14th, 2012, 1:01 am
