| Gearbox Rebuild. http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4398 |
Page 1 of 2 |
| Author: | Jonathan [ December 3rd, 2012, 6:54 pm ] |
| Post subject: | Gearbox Rebuild. |
After 223,000 miles the 'box is getting a bit ropey with the syncro on 2nd and 3rd getting tired and causing the gears to snick as I come down the 'box. I'm looking to replace the 2nd/3rd syncro hub, is this it?......... http://www.ecas2cvparts.co.uk/shaft-sli ... p-118.html |
| Author: | 2CViking [ December 3rd, 2012, 7:41 pm ] |
| Post subject: | Re: Gearbox Rebuild. |
Rebuild or repair? Don't expect miracles, the sliding pinion is reproduction. |
| Author: | Roy Eastwood [ December 3rd, 2012, 8:33 pm ] |
2CViking wrote: Rebuild or repair? Don't expect miracles, the sliding pinion is reproduction. |
| Author: | samfieldhouse [ December 4th, 2012, 3:02 am ] |
Out of interest Jon, I think it's worth quantifying 'rebuild/repair.' Viking repaired my box and seeing what he did, and the level of work involved, I can fully understand why a 'rebuild,' replacing only what is necessary, would cost in excess of €700. If you're changing the syncro, i'd stick with 'repair' or 'running maintenance!' |
| Author: | ken [ December 4th, 2012, 3:22 am ] |
synchro(mesh), svp. It's all Greek to me... |
| Author: | knightley [ December 4th, 2012, 10:28 am ] |
samfieldhouse wrote: Out of interest Jon, I think it's worth quantifying 'rebuild/repair.' Viking repaired my box and seeing what he did, and the level of work involved, I can fully understand why a 'rebuild,' replacing only what is necessary, would cost in excess of €700. If you're changing the syncro, i'd stick with 'repair' or 'running maintenance!' Exchange reconditioned gearbox from ECAS £495. Or Rick Pembro will rebuild for less I think. |
| Author: | Taskos [ December 4th, 2012, 10:45 am ] |
ken wrote: synchro(mesh), svp. It's all Greek to me... Not for me... By the way ,Jonathan, have you tried to switch to thicker oil? |
| Author: | Jonathan [ December 4th, 2012, 12:43 pm ] |
Cheers guys. I'm really wanting to do as little as possible (mainly due to wanting to keep as much of the mechanicals as original as possible-and also due to costings |
| Author: | ken [ December 4th, 2012, 1:31 pm ] |
Jonathan, if the gearbox has not been abused ( those 'racing' changes do take their toll on the synchromesh mechanisms http://www.ecas2cvparts.co.uk/synchro-c ... -1680.html Thing is that once the gearbox is apart to replace the clips, it's not that much extra work to replace as many bearings as possible, particularly those on the input shaft and mainshaft as they're not in an oil bath so tend to wear faster than those on the pinion shaft. ken |
| Author: | Jonathan [ December 4th, 2012, 2:55 pm ] |
Thanks Ken, are all the bearings available? I don't want to do a 'poor' job if it needs doing properly. If something needs replacing, it will be replaced if the part(s) are available. The reason for doing it now is because the clutch has bloody awful judder on take up, so the engine is coming out to see what's going on. I might as well have the 'box looked at, at the same time. |
