Reply to topic  [ 52 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Not just the key to comedy.........Timing
Post Not just the key to comedy.........Timing
After swapping the coil for a new bright yellow version form ECAS, I noted performance had dropped off a tad???
S'funny, starts ok, idles perfectly......
So I decided to cast my new timing light over the motor and see what's what.
Brilliant buy BTW, Classic Cars mag recomended buy and it works really well. GBP13.95 with free postage:
http://www.ebay.co.uk/itm/180660832618? ... 1439.l2649
Anyhoo, connecting up the strobe lamp shows the timing retarded by at least 2 degrees and I'm sure I set up the 123 accurately with my old Gunston strobe.
So I'm a tad confused but at least it's sorted.
December 2nd, 2012, 8:41 pm
Post Re: Not just the key to comedy.........Timing
yup ken has been advocating those for ages - and having used Smyth602 one today can only add to the recommendation! looks like a toy , priced like a toy but bloody good value and works an absolute treat no excuses for setting the timing statically anymore. ( and remember the light is not to check the static mark on the flywheel at tickover! >stern look<)
December 2nd, 2012, 9:00 pm
Without wishing to appear an idiot, what am I looking for when I eventually come to connect mine up to the Dyane? It was supposed to come with instructions but it didn't. What are the general principles of usiong a timing light?
December 2nd, 2012, 9:44 pm
In theory using another coil does not effect the timing....... however I don't know how 123 works...... Maybee it is giving more loading time (dwell) to the new coil now so your timing is affected, more dwell ==> later timing or as you say timing = 2 degrees off....
December 2nd, 2012, 9:48 pm
well as ive got a weeks worth of ironing to get through itll have to wait
oh ok then
you need to have some markings on the engine so you can set the timing - most cars have some sort of mark on the crank pulley and a degree scale or marks for important settings - our cars dont we have the static point where you put a peg in the hole and set the timing. so using this and the handy increments on the flywheel we can mark the timing. the 360* of the crank rotation can be divided by the teeth on the flywheel as they are a useful reference (360* divided by 107 teeth = 3.36 so each tooth that passes is 3.3* of crank rotation) we need a known fixed point there is no TDC on these cars only 8* we need a second point to show where max advance should be and an ideal max advance. 32* is a good safe max advance for an aircooled engine of that sort of compression ratio. so that's a further 24* from static or 7 teeth as teeth are our measuring scale
right the practicality bit
peg the flywheel mark the tooth that's under the engine /gearbox stud left( as you peer in the engine bay) of the starter nose -mark the casing opposite the tooth so that they line up thats the "datum" now pulling the teeth from under the starter with a screw driver count round 7,and mark it then go back to the static point and do it again and once your sure you are correct mark that 7th tooth
Connect the black and red crocodile clips up to the battery terminals clip the black clip over either HT lead. start the engine and point the gun at the Datum and pull the trigger. At idle the static mark will be to the left of datum (BECAUSE ITS THE STATIC MARK! and the engine is NO LONGRER STATIC!) it un important where it is. Now gently raise the revs as you do the static mark moves left into the bellhousing and the 7th tooth comes in to view from under the starter - it should go no further than the datum on the stud, adjust the points box till it does so. dont rev the nuts off it - only till the marks stop moving.
DONE! its actually really simple despite me prevaricating and avoiding the ironing board that has been placed beside me :(
December 2nd, 2012, 10:19 pm
Smashing, cheers. I'd worked out the bit about marking up the static point, but I couldn't see how that was going to get me any further forward than I'd got with the peg in the hole. :lol:
Enjoy your ironing. :twisted:
December 2nd, 2012, 10:29 pm
RT,
since I don't do ironing, here are some pictures, both static and moving to go with Sean's text... :lol:
How the flywheel would look if you could see through those bits of engine blocking your view.
http://www.flickr.com/photos/30132857@N ... hotostream
Strobe in use.
http://www.flickr.com/photos/30132857@N06/5449076261/
December 2nd, 2012, 10:38 pm
Ive never until reading seans post understood strobes. I own one. Ive tried to used it but never knew what to do really
Ive always set my timing with a test lamp at 2 and 1:4 teeth after tdc iirc
Chris checked with strobe after id done it once and it was spot on
Id like to use the stroe but i know how to do it the test lamp way and it suits me for now!!
One day maybe for strobe
Ps - do you count clockwise or anti (just for idiots like me!
December 2nd, 2012, 11:23 pm
Clockwise.
December 3rd, 2012, 12:11 am
James,
have you followed the links in my earlier post and read the text which accompanies the photograph?
(Where's the smiley for 'where's that rope', as I'm off to find the nearest lamp post? :(
December 3rd, 2012, 12:49 am
