View unanswered posts | View active topics It is currently November 20th, 2025, 4:55 pm
 Choke ?
Post Choke ?
How much if any choke do you give in the mornings?
my D*lly starts up fine even in the cold with none and when its cold if i give it a bit it nearly dies,engine runs well.mpg good,not bothered just wondered if its normal :?
October 25th, 2012, 8:37 pm
Post Re: Choke ?
Mine starts easily without any choke, but it wont run or idle without a bit of choke. It only needs about a mile though to get going properly. 1990 Special with a new coil :)
October 25th, 2012, 8:44 pm
Post Re: Choke ?
No choke required, especially if you have electronic ignition - give the accelerator a couple of dabs then turn over whilst holding the accelerator down a little and when it fires up blip the pedal until it runs smoothly....
October 25th, 2012, 9:07 pm
Post Re: Choke ?
1/2 choke to start, completely off after 1/2 mile.......
Back in the '80's when my 2cv was my only car, it was no choke to start and 1/2 choke for a mile or so
October 26th, 2012, 12:24 am
Post Re: Choke ?
None and a bit of accelerator if it hasn't been run in 24hrs or it's cold outside then tickover with a bit of choke for 10 or so seconds then nothing whilst running
I think some people drive all the time with some choke on - why? (Genuine question...)
Overly Ambitious Project
October 26th, 2012, 12:49 am
Post Re: Choke ?
Mine needs full choke and then ot starts straight away on the button
October 26th, 2012, 7:19 am
Post Re: Choke ?
Guess mines fairly normal then :mrgreen: thanks for replies :D
October 26th, 2012, 9:09 pm
Post Re: Choke ?
on mine i need half choke then without touching the throttle it fires up immediatly, it needs a bit of choke for a few miles till it heats up i,m running dg-nition and a high output yellow coil
i would advise anyone with the twin/ double barrell carb to unscrew the brass mixture adjustment screw at the lower front of the carb a tiny bit
its the one with the off-set screwdriver slot ;)
October 26th, 2012, 10:20 pm
Post Re: Choke ?
Nels,
I hope you're joking...
What's the point in the manufacturer providing a 'cold start' fuel enrichment setup on the carb, complete with fast idle interlink, if you're going to insist on annoying the neighbours by refusing to use it and play tunes with the throttle pedal instead? ;)
Since you mentioned electronic ignition, don't forget there's one brand of electronic ignition which sometimes isn't that fond of cold weather, making its displeasure evident by running on one cylinder for a while after it's woken up. :roll:
October 27th, 2012, 2:07 am
Post Re: Choke ?
Just like mine :D :D
October 27th, 2012, 8:58 am
