Condensor Issues
http://international2cvfriends.com/forum/viewtopic.php?f=7&t=4245
Page 1 of 2
Author:  samfieldhouse [ September 21st, 2012, 7:49 pm ]
Post subject:  Condensor Issues
Drove into tescos earlier - no problem. Shopped, returned to van and it wouldn't start. After some faffing, I changed the condensor. All sorted. Driven to london.
Parked up at my London place, packed the car and drove off. Got about half a mile and it does. Same problem. Except I don't have my spare condensor on me now.
I'm guessing it's tha same issue so why is the van killing condensors?
Author:  ken [ September 21st, 2012, 9:13 pm ]
Post subject:  Re: Condensor Issues
Sam,
if the charging voltage is too high, the condenser ( aka capacitor ) will be vulnerable to early falure.
Have you got a voltmeter on the van? Or a multimeter in the took kit?
Author:  ayjay [ September 21st, 2012, 9:17 pm ]
its possible that the new condensor failed sam, -there is a good modification you can do
you can mount/bolt the condensor just outside the points box by extending the wire a bit
it makes it far easyer to access it
condensors can either short to earth inside- or just go "open circuit" and not do their job(to reduce/minimize arcing across the points as they open)
also you might have a faulty coil, if its the original one
i might be wrong :roll:
Author:  ken [ September 21st, 2012, 9:52 pm ]
Although it's much easier to mount a replacement condenser next to the coil, especially if you're doing a roadside (or campsite ) fix. ;)
A pair of sidecutters soon isolate the old condenser in the points box...
Author:  Sean [ September 21st, 2012, 10:22 pm ]
+1 for the voltage reg
Then get something that does away with them they are the weak point no matter what you call them or how you spell it
Author:  ayjay [ September 22nd, 2012, 12:37 am ]
if the voltage reggy was playing up and allowing over volt/current, the battery would be cooked :?:
condensors are strange things!, difficult to test!apart than if they are open circuit or short to earth :?:
Author:  FDK683 [ September 22nd, 2012, 1:25 am ]
it was a problem with failing condensers that led me to buying 123 ignition.
I am quite happy not having to take the fan off on a regular basis
Author:  samfieldhouse [ September 22nd, 2012, 1:29 am ]
I have a handheld electrical tester thing - last week battery was ok at 14.3 when revved, reg was new in may. Where does the condensor go in the circuit? And what could I Replace it with?
Author:  dave 411 [ September 22nd, 2012, 9:05 am ]
Sam,Sean has a black box that does away with them.I cant remamber the name of them,but I am sure he will be along soon ;) .
Better sort it out if you are going to the van show/camp in Holland.
Author:  Taskos [ September 22nd, 2012, 6:27 pm ]
Coil.
