View unanswered posts | View active topics It is currently November 20th, 2025, 4:55 pm
Reply to topic  [ 8 posts ]
 Brake line - psi
Post Brake line - psi
What sort of psi/bar do you get in a 2CV brake line?.
I have a gauge/adapter to check.
But if a guru has the info already to share ;) .
September 16th, 2012, 10:59 am
Post Re: Brake line - psi
For 2CV6 AZKA after Feb. 1970 it's 6 to 6,5 bars/6.000 rev/min at 80"C with 20W40.
I've Been Wrong Before.
September 16th, 2012, 1:24 pm
Pete,
hope the gauge reads high enough, as the only reference I've ever found to brake line pressures was for the Mehari 4x4 with a pressure limiter in the rear circuit. ;)
Iirc, that reduced the line pressure from around 80 bar to 25 bar.
September 16th, 2012, 1:39 pm
Ken,
Thats useful, thanks.
Have a gauge thats reads to 70bar, see pic.
I will have measure a front brake caliper with it.
GS manual states the brakes work at 60 to 80 bar.
My electric pump gives 20 bar, may be sufficient to apply some brake pressure.
Otherwise it's an LHM pump + accu solution.
Peter
September 16th, 2012, 4:37 pm
Sorry that's for the lubrication line... :oops:
September 16th, 2012, 10:06 pm
File It under - "Engine Braking" ;)
September 17th, 2012, 11:54 am
Gauge doesn't read high enough.
Its round to the start peg :o
1400 psi?
September 26th, 2012, 4:10 pm
meaning that it works????
September 26th, 2012, 5:24 pm
