View unanswered posts | View active topics It is currently November 20th, 2025, 4:49 pm
Reply to topic  [ 3 posts ]
 Lighting Control Switch Mod.
Post Lighting Control Switch Mod.
Why is this terminal missing? :?:
Let's place an extra contact feed some 12V and see what happens...
Placed down, when the switch is in 0, it is not in contact with the 12V cylinder.
Placed up, and it is in contact supplying the main beam which is in contact with the cylinder.
In all other possitions of the switch 0,V,R, has no effect and the switch is functioning as before.
In conclusion, what you have is a simple main beam signaling to fellow 2CVers during the daylight. :D
I've Been Wrong Before.
September 15th, 2012, 9:19 pm
Post Re: Lighting Control Switch Mod.
I like the idea the lack of flashing ability to fellow 2cv drivers restricts it to waving IMO...
However , can this be run via the ignition so that it cant be nocked on as you exit the car and come back to a drained battery..?
September 15th, 2012, 9:33 pm
Nice idea...
You'll need an extra wire coming from the ignition switch, and check the wire capacity, otherwise I don't see any problem.
I have a audible warning for lights on...
September 15th, 2012, 11:01 pm
