View unanswered posts | View active topics It is currently June 19th, 2026, 5:20 am
Reply to topic  [ 3 posts ]
 Squealing Thrust Bearer
Post Squealing Thrust Bearer
Hi
put a new thrust bearer on there around February and adjusted it to give a gap of about 1mm
no problem with the transmission or clutch at all but the squeal from the thrust bearer is becoming annoying now. only does it when pulling up to a stop / riding the clutch - only started happening when i tightened up the gap (to about 1mm freeplay)
it's an old style tin top box with the sidehung lever arm
any thoughts? will it go away over time?
cheers
will
May 20th, 2009, 12:44 pm
Post Re: Squealing Thrust Bearer
Willami wrote:
Hi
cheers
will
Have you oiled it? IIRC ATF fluid or 3 in 1 (better look in the handbook to be honest, I can't really remember) down the little oil filler thing by the fork. Mine never squealed but it took a long time of lubricating it and using it before it stopped dragging and slowing the engine down when the clutch was pressed.
May 20th, 2009, 9:17 pm
ah, yes i wondered what that little 'brass cup' with iron wool in it was.....
will have a go with some 3in1
how's your van conversion going?
easy now
May 21st, 2009, 12:33 pm
Users browsing this forum: No registered users and 242 guests
